Even though the commercial skip box is checked the commercial skip, yellow underline, is not working. This is happening more frequently in the last month. Also, sometimes the skip gets over zealous and skips through a couple segments of the program.
Hi there - Sorry you’re running into this.
If you can send some additional details to support (which Tablo app you’re using, recording name, date, timestamps of when the skips do not occur) the team can investigate further: www.tablotv.com/support/#contact
