Commercial skip records about 60% of the time. It will record a show then miss the next show on the same channel, and same show!
This can happen on any channel or show.
I have checked my subscription, made sure the feature is active and even did a refresh.
Hi Bob -
Can you clarify exactly what you’re seeing?
Your recordings are completing as expected but Automatic Commercial Skip isn’t present on all of the shows you expect it to be present on?
What type of error messages are you seeing on recordings that don’t offer Commercial Skip where you expect it?
Some specific examples would be helpful.
I’m having numerous shows where I get error message “Commercial skip detection failed.” Less than 50% are working properly. It is not a result of poor reception. Happens on different channels and different shows.
