Will there be the ability to use the commercial skip feature WHILE using tablo connect now that betta testing is complete?!
Yes I believe Com Skip will work only if you set the “Remote Streaming Quality“ to “Full Quality” when using Tablo Connect.
But on what device are you using Tablo Connect?
That’s correct, but none of the apps that support Tablo Connect are currently also apps that support Automatic Commercial Skip.
It won’t be until the mobile & web apps are released that you’ll have a platform that does both.
