All of the sudden all my channels are coming up in closed caption. I checked my settings on my TV snd it’s set to off. Should I reset my Tablo?
What streaming device are you using?
Apple TV
Did you check the closed captioning setting on the Apple TV?
Yes and they are set to not be on
The setting might be stuck on the ON state.
Try rebooting both the Tablo DVR and the Apple TV.
Thanks for your help that did the trick. Much appreciated
