Hi,
Having a problem with Android and Chromecast. Hoping someone with a 100% operational Tablo+Chromecast can let me know what configuration is working. Or, can chime in with more data if they also have a problem. I have posted a trouble ticket but Tablo support cannot reproduce problem.
Everything works perfectly for about 45mins then gets problematic in two ways:
The app occasionally starts hard crashing while FF/RW. I get the "Tablo has stopped working, I usually press the report so that you will have the information. I usually tap FF through commercial breaks The chromecast will continue to play but the app has to be restarted.
The app almost always looses its association with the currently playing shows. FF/RW and sweeper bar will stop functioning. Sometimes I can re-enter app and recover location. Chromecast will continue to play but the app has to be restarted.
Configuration:
Table 4 tuner
Android app (release 1.0.25-616/3000278)
tablo (2.2.8):
Netgear R7000 with wired connection to tablo.
Chromecast 2 and Chromecast 1.
Nexus 7 (2013) running Android 6.0.1, Nexus 7 (2012) running Android 5.1, and Nexus 7 (2012) running 4.4.4.
I use SD quality.
I have tried 720 at 3MB/s.
Disabled “Fast Live TV startup”
Disabled Leanback Mode
