Chromebox MOO4U?
Will tablo work with a chromebox?
You can run the web version my.tablotv from chrome like any other computer. Runs perfectly on my Chromebook.
Since it is basically a pc with a Chrome browser, it should work just fine.
Thanks!
I can confirm it works fine with a Chomebox using the Web app…
If your using the Chromebox on a TV, you might want to enable the “Leanback” mode in the Settings of the Web app for a better 10-foot UI experience.
You don’t have lipsync issues? I do on my Chromebook and Chrome browser on my desktop :frowning:
Rarely, but it has happened. Usually a restart of the stream fixes it for me. I don’t see it on my Pixel unless I’m really pushing the tabs.
