Want to go OTA antenna, coax to Tablo, and OTA to Amazon Firestick. One tv only. Which tablo do I need, N/W connected it TV connected?
If you only plan to use one TV and are OK with using a separate dedicated Tablo remote, an HDMI model may be the best solution for you and you don’t need a Firestick to use it as it connects directly to your TV via HDMI. However, if you want to use the Firestick as the primary interface, one of the network-connected models may be the best solution for you but you’ll want to have a robust network and connect it to your network via Ethernet if possible.
See this article for additional information that may be helpful in making a decision…
