Certain channels work fine, then freeze up when sent to a TV via Chromecast.
I’ve been using this for < 24 hours and have run into nothing but problems.
@TableSupport - haven’t heard from anyone…
I moved my antenna and it seems to be resolved. It seems that if the signal is not adequate it just freezes? It would be great if it indicated that the signal was lost or something.
i take it back, still happens with a full signal periodically (e.g. doesn’t seem to be related the the signal strength). If I can’t stream it via Chromecast with the reliability I get from Netflix, Hulu+, and Plexserve…
