Channel turning?
I have a rotating antenna and would like to know if I can pause or some how add channels to the already existing channels with out having to start over from scratch? If I scan for channels while my antenna is pointing ( EXAMPLE ) north, then I rotate it to the east can I add more channels to what I already have? If not can this be added as a feature ?
Don’t think Tablo is made for rotating antenna. You can combine two fix antenna with a combiner or what I use an omnidirectional antenna.
Unfortunately Tablo isn’t designed to used with rotating antennas. There are some alternative suggestions here:
Thank you. Looks like I need 2 antennas instead of a rotatory system. It was a good link with the information I was looking for.
