Channel Scan results: Engine vs Tablo 2/4 question
using a USB 3.0 WD standard drive (one of the approved Tablo ones since they are picky what works on the OG models)
Just out of curiousity, if it is a Shield related problem, what does that do in terms of continuing to use the Engine? With the pixelation problem, is the Engine usable or tolerable?
A year ago, with the Roku problems then, many here felt the Tablo to be unusable with their Rokus until Roku came through with a major fix.
If all the core functions still work and is stable otherwise for me I’m going to continue using it and hope Nvidia fixes the pixelation.
My biggest issue with Engine and I know its still pretty new so maybe this will come is not being able to remotely schedule a recording and not being able to search/record FROM engine (need to do from the app or web app right now) and the inconsistency being able to get into the web app or android app for Engine. OG seems to be fine but Engine its 50/50 shot if i get the failed connection or not
