I’ve been using Tablo with Ethernet for about a year. I need to start using WiFi to use a better antenna. I can’t get Roku to find the Tablo device. When I connect to my router, it says “no internet access.” I’m not sure if the connection is the problem.
Did you try accessing your Tablo DVR with another device like a phone or a tablet to make sure that your Tablo DVR is properly connected by wifi to your router?
I don’t think that it is connected correctly to my router. It was hard wired to the same router and was working.
Read this guide - you can’t use your Roku to make these changes. Use an iPad or iPhone, or tablet or smartphone.
The link below is how to add your Tablo to WiFi using a computer (in the Chrome browser):
