Hi, i just got a tablo 64 gb, installed via wifi( tp-link 7 archer router) with app on ipad ,iphone 7+,apple tv 4.
if I tune a channel, i can’t switch for another one and got player error…poor reception. Tried reboot, factory reset, deleting and reinstalling app, same thing.Sometimes i can switch if press recording first but returning to the previous channel i get the same message. What could be wrong?
Maybe you have poor reception? What kind of antenna are you using? How far are you from the broadcast towers?
Check out:
http://www.tvfool.com
it’s not the reception. i got 25 channels with 8 bay channel master who plays fine on tv. if i chose first a “poor channel” tablo plays it but i cant switch to a second one, i’m stuck with it. to tune another one sometime is working if i press recording first…
but no recording do to message "poor reception "
If you got such a huge antenna and are close to the broadcast towers, you could be over driving the tuners in the Tablo. Drop an attenuator or splitter before the Tablo.
