I have the news scheduled to record every day M-F, then a second set to record on Sa-Su (different channel).
Lately the M-F recordings don’t show in Tablo until I bounce around the different Recording screens (ALL, TV Shows) a couple times, then, eventually, it shows up, Took 8 minutes today (show records 6am-7am, finally able to see it at 7:10).
The Saturday recording rarely occurs. It’s scheduled at 6-7am, according to the schedule the next recording is Oct 3, so it’s already planning on missing one week, and it didn’t record at all this past Saturday.
Are you running the latest firmware (2.2.30)? There was a similar sounding problem reported in 2.2.28. Then it was recommended to delete the recording schedule and then reschedule it. That worked for me in a similar situation.
I record it because I’m not up when it’s on, so it’s always after the show ends that I am trying to get into it. Sure, only a few minutes later, but still later.
I’ve seen this on Roku and Fire TV Stick on all 3 on my tablo units.
You could see the recording in the browser app and the original fire tv stick app. If you play and pause the recording in either of those apps it would then appear in the Roku app.
And once the recording completes all appears as normal
But, for me, it’s been going on for a while. And didn’t freak me out as much as in 2.2.30 when some random recordings show up with an elapsed recording time of “1 <=”. And the whole recording is there.
Sorry, I spent 40+ years in IT, it bugs the heck out of me when simple things don’t work. We’d spend weeks testing changes, even get users involved in the testing, before we released anything. I don’t see that type of quality control around anywhere these days. Make changes, test out the changes a little, don’t check the entire system, hope it works.
I can understand that both active recordings should continue, the new one should pick up when one of the active recordings ends. But both active recordings stop? Weird decision path.
Yeah. I went with the Quad, both for the 4 tuners and the ability to swap out storage devices. I currently have a 1TB Book, which I can expand up to 8TB if needed.
