Can't connect to tablo
Ever since I changed my Internet I’m having trouble connecting to my tablo 4th gen it won’t give me a choice on wifi even if I turn the modem off how do I change the wifi connection
@TabloTV I asked this same question once before when I was setting up a new Tablo 4th Gen device. I have my wifi networks segmented into separate 2.4 and 5 gHz nets; I mistakenly connected my Tablo to the 2.4 network, then wanted to change it to the 5 gHz network. I got an answer from Tablo at the time that the capability to switch wifi networks was not yet built into the 4th Gen Tablo.
So, question for @TabloTV @TabloEngineering : Is there a capability yet to switch a Tablo 4th Gen device from one wifi network to another? If yes, how do we do that? If no, is it being worked?
Cheers.
