Cannot live stream while recording
Received my in warranty replacement and it worked fine until I tried live streaming while recording. It buffers and won’t load, or it just doesn’t connect. Works fine when I’m not recording. Have reset with no success.
Sorry you’re running into that.
Would you consider reaching out to our support team again https://support.tablotv.com/hc/en-us/#contact ?
They should be able to help.
