We had a power outage yesterday. When power came back on we started to have problems with our Tablo.
Retrying in 1 seconds…
I had the same problem a few weeks ago. I tried clearing cache, clearing all browser data finally solved the issue. Makes sense, you can connect to the IP the browser appears to be the problem.
Make sure they are all on the same subnet and there’s no isolation going on in the new router
I went into history on chrome & cleared everything. Hopefully Tablo support will help me tomorrow.
I had to reboot my tablo after my Wan IP address changed (when I dropped Verizon Tv service). Same thing could have happened to you when you replaced your modem. When you use my.tablotv.com, the site connects you to your tablo. I suspect that Ip address changes aren’t getting communicated to my.tablotv.com.
I checked my account on tablos web site & my new internal address matches what they have listed under my account. So the new ip address did get recognized. I am at a loss…
@PhilH Are you using a VPN of some kind?
No I’m not. I received an email from David & he requested logs. I have sent them to him…
Did you try unplugging the HD and then rebooting and then try to connect?
I was having a couple of other issues so I formatted my c: drive & installed Windows 7 from scratch.
I just had a similar issue. Watching tv then it was just gone. Roku says no tablo on my network. I can’t access it via my laptop either. I have rebooted router, tablo, and roku. Thoughts?
Delete the Roku channel, restart the Roku and then install the channel again from the link on the Tablo website.
Read this thread for more:
http://community.tablotv.com/discussion/1426/resolved-as-of-yesterday-evening-all-3-of-my-roku-s-unable-to-find-your-tablo
This morning I was able to connect to the Tablo from my desktop. I don’t know if Tablo Support fixed it or what but it now works.
I don’t believe it. I can’t get to the Tablo again. It just tries to connect all over again…
Well I said heck to it all & deleted the partition on my C: drive. I installed Windows 8.1 Pro 64 bit and all of my problems went away. I can now connect to my tablo and sync to my hearts content.
No offense, but can i take a snapshot of your message? It’s the very first time I have ever seen the phrases “I installed Windows” and “all of my problems went away” used in the same sentence.
LMAO - Sure you can… lol
Win 7 is great too
My eyes! My eyes! They burn!
roflmao
