I have the 2 Tuner Tablo and have pre-ordered the the 4 Tuner. Could I run them both (assuming I’m splitting my signal).
According to @TabloTV yes. they will have a nice switching function that allows you to switch between devices. There is another thread showing how it works. ACtually i believe it is already in place…
Thanks!
@ltldevl - That’s correct. You can run multiple Tablo units on a single network. You just need to choose which Tablo to connect to within the app.
