Is there a way to rename a manual recording? I found the rename feature on my tablet, but it doesnt seem to work… anything Im doing wrong?
I definitely can’t do it on a PC, so I doubt there is any way to do so. Just create a new manual recording with the appropriate name.
Are you referring to a Saved recording in Tablo Ripper? If so (and if using Windows) just right, select “rename” from the ensuing menu.
