I have been connecting via Chrome all along but suddenly, my Windows 10 machine running Chrome cannot connect to the Tablo box. I tested it from my phone and from Roku and all is well there. While the session was connecting in Chrome, I pressed F12 to get the console. The log contains an entry saying “1f182c1….js:190 Object {uri: “/error/session/connect/permissionDenied”, desc: “Authentication failed↵”}” which I suspect means that there is an authentication failure. I have tried clearing the cache with Chrome, and I ran CCleaner to clean up everything it can find. I deleted the sync data, restarted chrome but no matter what, I get a dialog box showing “There was a problem establishing an authenticated session with your Tablo. This could be due to either authentication or internet connectivity issues.” and an entry in the log as described above.
I get the same problem with my laptop but I had not been using it to connect so this is not surprising. Also I just purchased the subscription for the schedule. So I had to create a new account for this.
Has anybody got any ideas for me?
Thanks
