Problem: Live streaming remote underflows buffers every 7-10 seconds requiring 5+ seconds to restart.
I have had this configuration (or one slightly inferior) for several years with successful remote viewing. This problem cropped up in the last 12 months or so.
Test Configuration:
Tablo: Model No. SPVR2-01-NA; Serial No. LD-B025606; Device 2.2.26
DVR HDD: WD Elements 10B8 1012 2TB
Tablo local network is Gigabit Ethernet Cat5e Hardwired
Tablo internet service is AT&T gigabit fibre; speedtests at 970Mbps up and down
Local clients include Moto X4, iPad, Roku, nVidia SHIELD (Version 2), Nexus Player
Remote LAN is Gigabit Ethernet Cat5e Hardwired and 2.4/5 GHz WiFi
Remote internet service is Charter 60Mbps service with speedtests reliably at or above 60Mbps
nVidia SHIELD (version 1) hardwired to router with latest Tablo app
Moto X4 (Google Project Fi) with latest app; tested at 2.4 & 5 Ghz with and w/o VPN
iPad with latest app on 2.4 & 5 Ghz
Tests & Results:
- Live playback on local network: initial buffer under-run; pause to re-buffer; remaining playback w/o buffer under-run
- Recording playback on local network: no buffer under-run
- Live playback on remote network: initial buffer under-run; pause to re-buffer; play for a few seconds; pause to re-buffer; rinse-repeat
- Recording playback on remote network: no buffer under-run
- Behavior is consistent across all devices at both local and remote locations
- Remove HDD and re-run Live Tests: No change in behavior with Live playback local and remote
- Adjust all Bitrates (Live, Recording, and Remote) from highest to lowest settings: no change in remote buffer under-run and never induced local buffer under-run
- All Playback tests are run w/o background recording or multiple stream playback and always on the same live channel from test to test
Observations/Conclusions:
Because Remote playback of high bitrate content plays correctly the problem is NOT END TO END NETWORK BANDWIDTH
Because Remote playback fails with and without the Hard Drive the problem is NOT A TABLO “LIVE-PAUSE BUFFER TO HDD” ISSUE
Because this exact configuration worked well in the past it would seem this is a software issue related to the buffering at the server, the client or in the signaling between them
Questions
- Has anyone else experienced similar issues?
- Is there anyway to access logs or increase logging levels on the Device firmware or the apps?
- What is the best way to engage Tablo Tech Support to resolve the issue?
