I installed the Android TV app on my new Sony TV. The recordings play fine (and look beautiful on the 65" screen if from an HD signal), but watching Live TV has constant, intermittent buffering. I’ve disabled the “Fast Live TV” option so that’s not the problem. And I’ve ruled out most of the other problems:
Strong TV signal from a tower 7 miles away
Tried several different channels with the same problem
Tablo hardwired into AC1900 router
TV is streaming from Tablo on 5ghz wi-fi channel and all other streams (including 4K from Amazon and Netflix) coming over fine
Throughput is over 1 gbps on my internal network
Tablo is updated to latest firmware as of 11/29/15.
A few other possibilities that came to mind:
Buffering seems worse when I’m also recording another show during a Live TV stream. But I might be imagining that. Should it matter?
Does the “recording quality” affect the processing power when streaming Live TV? I thought there might have been less buffering when I dropped the quality from 1080p to 720p, but also not sure.
I know it takes up more bandwidth on my home network, but I’m pretty sure this isn’t a network capacity problem. For instance, I can stream 1080p recordings without any buffering. When I’m on Live TV, there’s buffering at both 720p and 1080p, but I think there’s less at 720p, which is why I’m wondering if it’s a bottleneck on the Tablo processing side.
I’m hard wired Gigabit throughout the house. Cisco commercial router and switches. I see the exact same problem with Roku and live television. The problem is worse with 1080i @ 10Mbps. I get maybe one buffering incident @ 720P @ 5Mbps. It seems like the guide is updating or something like that when the buffering incidents occur.
Good to know. Maybe my problem was extra noticeable b/c I had just installed the app and the Guide was updating. It seems better since yesterday’s update so maybe it’s a false alarm.
