Hello,
I’ve been a TabloTV user for just over two years. Back in October 2015 when I got my unit, I set it up and found as many of the local channels as I could get with the channel scan. I trimmed out the ones I didn’t care about. In one case in particular, Austin TX Fox Ch 7, it was not a good signal, and I would usually get the “Weak signal” error when trying to tune to that channel. If I got it at all, it was very blocky and difficult to watch.
I got lucky though, as that same local channel was provided by SlingTV, so I could get it over the internet.
So, fast forward to a week or so ago. I heard about a few new stations in my area, and I re-did the channel scan for the first time since I bought and installed the TabloTV. I saw a few new ones, and changed my channel line up. Well now, for some strange reason, Fox 7 comes in perfectly after this scan. I checked with Fox 7 and they have not changed anything about their broadcast strength. I have not touched my attic antenna.
I know that today I am using firmware 2.2.16. I do not remember what firmware I had when I originally installed the unit, but it would have been whatever was current in late October 2015.
I’m not really here asking for any support, but I am suggesting to folks that if you have historic channels you could not receive well, you may want to try a new channel scan to see if you get different results today, than when you first installed your TabloTV units. You might be surprised.
Thanks!
