Beta update 2.2.5 frozen on Installing?
Evening,
On a Fire TV and the beta program, was notified of an update to 2.2.5 and went through the usual download but its been spinning on Installing for 30 mins now… Should I pull the plug on the box and restart or…?
Thanks
Ah, pulled the plug, restarted and all is well…
I had to do the trick where you disconnect the drive after updating … then once the tablo is booted but showing “NO HARD DRIVE” connect the drive.
