Every channel is cutting out constantly and the video actually loses time its so bad.
As a test try running the Tablo without the hard drive, then try Live TV to see if the problem resolves.
Update. Things seem to be back to normal didnt do anything different but this morning its better.
Glad it cleared up! I wonder if you had some localized interference with your TV signal.
