Found this on the Plex forums. First off I’m not a programmer or coder nor do I play one on TV. This is a Fix if your Plex updated and the Tablo Channel is stuck on Loading… I have Plex server running on my Mac OSX 10.11.4 and this got the channel working again. I’ll make this as simple as I can.
- From the Finder GO > Go To Folder…> ~/Library/Application Support/Plex Media Server/Plug-ins (Click Go)
- right+click on Tablo.bundle and select “show package contents” then open contents folder
- open the “Code” folder and open the file “__ init __ .py”
- Do a command+F or search for R(ART) We are going to be removing those lines or commenting them out.
so…
ObjectContainer.art = R(ART)
DirectoryObject.art = R(ART)
VideoClipObject.art = R(ART)
are whats screwing up the plug in. I just commented mine out by placing a hashtag and a space before each of those lines as indicated below then Save the file. From what I understand this would also potentially fix other channels by removing the R(ART) lines.
# ObjectContainer.art = R(ART)
# DirectoryObject.art = R(ART)
``# VideoClipObject.art = R(ART)
Relaunch your Plex Tablo Channel and it should now work as it did before the Plex update. I can now retire my AirPlay device
