I have a new Apple TV 4 that simply will not connect to my network via Ethernet over copper.
I have another Apple TV and a fire tv that are both connected via Ethernet over copper on my network.
One recommendation so far has been to reboot the router…
My question is if I reboot the router, do I need to do anything with the Tablo? And just to be sure, I’ll probably start with a reboot of the cable modem. Then setup the router again.
Then I’ll make sure all of the Ethernet over copper devices are synched up.
Then I’ll t st connectivity on the FTV & the 2 ATV 4’s.
What should I do with the Tablo at this point? I’ll also post this over on Reddit as well.
