Has anyone else encountered this issue? When we stream recordings via AppleTV, the stream frequently seems to get interrupted and Apple TV resets back to the main screen. Not sure if it’s the Tablo or Apple TV that is causing the problem. We tried streaming from both an iPad Mini and an iPhone but the same seems to happen. It’s almost like it’s got trouble accessing the recording.
It only seems to happen with some recordings and is very intermittent (although when it does happen it seems to happen frequently and pretty consistently). My recording quality is set to HD 720 - 5 Mbps and running Tablo 2.2.8 with app version 1.0.25-616/3000278
I Airplay from an iPhone 6+. It hasn’t caused any issues with the AppleTV4. However, if while streaming, I press Menu on the remote, the Tablo app on the iPhone becomes unresponsive and I have to clear the Tablo App and restart it. Sometimes even that doesn’t work, but if I go to cellular and connect to Tablo it works, then go back to WiFi and it continues working.
