Apple TV app thumbnails?
Does the Apple TV have thumbnails when fast forwarding like the roku does?
I just got the Apple TV a few months ago and I’ve never been able to have this show up…makes it hard to fast forward. and yes there are free tuners.
@jbsmith_05 - Yes it does. You can read about all of the features here: https://www.tablotv.com/blog/tablo-app-apple-tv-now-available/
Please note that thumbnails will only be generated for completed recordings. If you’re trying to get thumbnails on an in-progress recording, this is not possible. https://www.tablotv.com/blog/tablo-faqs-why-dont-i-always-see-ffwd-previews/
Thanks I did finally find that last night!
Two questions…
  1. Any plans to make the preview image a little bit bigger? I have a 46" tv and it seems pretty small and hard to see - at least compared to the roku app (that was replaced by the apple tv)?
  2. Is there a way to fast forward with the preview up similar to how the roku works - by holding down the right arrow on the roku remote? I know you can slide/swipe on the apple tv remote, but I find that difficult to control as it either goes 15 min forward or I’m spending a lot of time trying to get it just right…
Thanks!!
@jbsmith_05 - A lot of the player attributes (like the size of the FFWD previews) is controlled by Apple so we don’t have a lot of choice on that.
As for Fast Forward, the Apple TV remote is a bit different than Roku… You can use the slide/swipe or use the directional pad to get most of the way and then just click it to find the ‘right’ spot.
Thanks!
