I am getting deep into Home Assistant and would love to add some Tablo information to my dashboard such as next scheduled recording. Is there any public API for access to these things?
No there isn’t.
It’s not open/public as FlyingDiver says, but Tablo does have a developer program which gives access to an API under an NDA. I built an Android app using it and it’s pretty intuitive (though operable only on the network local to the Tablo). The folks behind the official Tablo accounts can connect you and get you started if you’re interested.
Good luck!
Thanks, yes I got in contact with them and working on it
Local is perfect
