I don’t believe the tablo has the processing power to cut commercials, It saves videos as a series of individual files (which is nice because with overlapping shows the overlap needs only to be recorded once), but I don’t think it has any ability to further cut those files.
The ability to download a video directly from the Tablo would be nice, but for those of us who want a bit of automation we are going to continue to need external scripts (I download videos automatically and watch everything via Plex).
Now if only @tablotv would bring multichannel audio…
I also have a problem since 2.2.8. The following is kind of a subset of what I am seeing now. As you can see, 26 are new, but 25 are duplicates ( I don’t believe this ). It says that 1 video is queued, but then never downloads it.
[kkoceski@E4300_XFCE TabloTV-SD-500GB-TS]$ python2 ./tablo2go-2.0.55.py -tablo:192.168.0.101 -mp4:False -tempdir:./tmp
[Dec 1 12:00:20 2015] - Starting TabloToGo Version 2.0.55
[Dec 1 12:00:20 2015] - Loading download history
[Dec 1 12:00:20 2015] - 4345 shows and movies have already been downloaded
[Dec 1 12:00:20 2015] [192.168.0.101] - Found Tablo named Manually Entered
[Dec 1 12:00:20 2015] [192.168.0.101] - Loading meta-data for 523 recordings
[Dec 1 12:00:39 2015] [192.168.0.101] - 26 new TV, 0 movies, and 0 sports
[Dec 1 12:00:39 2015] [192.168.0.101] - 25 matching videos are duplicative
[Dec 1 12:00:39 2015] [192.168.0.101] - 1 matching videos have been queued
Not sure if you’ll find this helpful, but certain metadata values have “moved” in the JSON Tablo response as of version 2.2.8. That caused some issues with TabloRipper (which have now been resolved). But it could be the cause of your issues too.
I created a new folder and copied tablotogo into it. I started it up at lunch, and it looks like it is going to download the whole drive to the new folder. So, I’ll preface this by acknowledging that I don’t know what I’m talking about, but it seems that it’s a case of an incompatibility between pre-2.2.8 and 2.2.8 concerning the .history file ???
I found my problem went away the next day. Never mind.
One thing I am curious about is that some recordings reappeared, but I can’t download them with any of the export programs.
EDIT - Yesterday I had major problems trying to download programs on any exporter. SurLaTablo seemed to work, but I only got a .ts file that I can’t do anything with.
Thanks for taking a look this weekend. I really appreciate TabloToGo and use it several times per week.
FYI only (in case it helps diagnose) - I can report the exact same problem here (TabloToGo 2.0.56) since the 2.2.8 firmware update. It seems to have lost the ability to see the recording IDs. For example:
EP010146820126 Murdoch Mysteries - S09E07 - Summer of 75
is now just
. Murdoch Mysteries - S09E07 - Summer of 75
I can’t download new shows from the Tablo. Log sample:
[Dec 1 21:04:38 2015] - Starting TabloToGo Version 2.0.56
[Dec 1 21:04:38 2015] - Loading download history
[Dec 1 21:04:38 2015] - 363 shows and movies have already been downloaded
[Dec 1 21:04:38 2015] [192.168.2.11] - Found Tablo named Manually Entered
[Dec 1 21:04:38 2015] [192.168.2.11] - Loading meta-data for 164 recordings
[Dec 1 21:04:45 2015] [192.168.2.11] - No videos have been queued
Thanks, thats helpful, I look through the metadata and adjust the script. I have this software running as part of an automatic (cron) job on my system and would have never noticed that it wasnt working. (I still use my OTA TiVos as my primary recorders until the Tablo can handle multi-channel audio - hint hint / beg beg @TabloTV )
Let me know if you need any help testing anything. I looked through the metadata too and it looks like the program details were removed in the latest release.
Well this is really annoying. They removed all of the interesting metadata, and more importantly they removed the episode id / show id from the metadata. I was using this because they were providing the same ID’s that TiVo was using and it allowed easy deconfliction between the two (if TiVo missed it I would grab it from the Tablo), and more importantly to everyone else, this is how I was preventing you from downloading the same show twice…
@TabloTV was the removal of this metadata intentional?
This effectively makes the TabloTV useless to me.
I uploaded a new version of TabloToGo (2.0.61) that will replace the episode id with series.season.episode.espisode_title just so the program will not download duplicates and be useful again to everyone else.
Thanks so much for for the update. Like you, I found the metadata very helpful and have saved my .history file.
I’ll D/L your new version and test. FYI for those following along, I found the tablo2go download site (from wayyyyy up in this thread) at Sign in - Google Accounts
