@krissy, thanks for the catch, b41 posted and the old version deleted.
@jskenny,
@krissy - b42 has been uploaded can you provide -sports -list again
b43 has been uploaded
Wow - This is awesome !! I just started reading this thread last night and in a matter of minutes I was successfully downloading shows from my Tablo.
@jskenney - thank you for your work. Would it be possible to run a script with comskip to process the recording?
@7up - I was thinking about trying for comskip in the following version of the script, a bit more than I am willing to take on over this holiday. Personally I have never cared for it, as sometimes it guesses horribly, and your file is broken by it. If you are comfortable scripting, another script to be run on the output of this one until that gets built in.
@jskenney - I agree, Compskip isn’t perfect but I think its still worth trying to figure out how to integrate into Tablo. Thanks for considering in the future.
I am using MCEBuddy with Comskip and it’s not perfect but it is acceptable. You might want to try that out.
@jskenney One other suggestion on the logging side of things. Would it be possible to use Python’s logging module for the logging to a file functionality? It supports file size and log file rollover which would make the automatic cleanup of the logging file easier. If you can’t get to it I can modify and send you the changes.
@mjarends - I doubt I will have time to get to it at this point, I am happy to take code though, please forward it along.
b45 has been uploaded with significant updates in file naming support (please check, this is one of those things that needs testing)
Ok, nearly done. Uploaded 2.0pre1, please test. I plan to upload the final version tomorrow and consider this version done, and I’ll look into tackling more during the next holiday (summer).
‘custommovie’: [’{title} ({recMovie.jsonForClient.releaseYear})’, ‘SEARCH’, ‘Custom File Naming’],
‘log’: …
File “tablo2go-2.0pre1.py”, line 936, in
show_proc = proc_meta(show_info, OPTIONS)
File “tablo2go-2.0pre1.py”, line 669, in proc_meta
PROC[‘name’] = custom(OPTIONS[‘customsports’][0], PROC, convert(metadata))
File “tablo2go-2.0pre1.py”, line 240, in convert
results[k] = OPTIONS[k][0]
KeyError: 0
@krissy - Uploaded pre3 - looks like I made a few mistakes last night on the custom file naming, try it now.
@krissy - The -list sort is always alphabetical by filename, if you use the -custom commands it should just be changing the filenames and still sorting them all (they will be sorted together), are you seeing something else?
