I ask as I’m going to have to install one in order to get all the channels at the greatest strength.
So, do you have to rescan every time you move the rotor?
How exactly will that work?
Thanks in advance.
een
Thanks in advance.
@een - Yes, you would have to rescan when you move the rotor. Several users do use two antennas and a combiner though to achieve the same results.
Well, rotor looks like something I don’t want to do.
Double antenna it is!
