Although I agree with the notion that modern SSDs can compete favorably with traditional hard disks, it is much more true when they are used in conventional computer systems.
In PVRs and DVRs like the Tablo, the utilization of the drive is very different.
In a computer system, many if not most files are increasingly added to the drive, filling the unused blocks with relatively static content which stays in one place for years or many months, usually to be read rather than frequently rewritten.
In video recording systems such as Tablo, the blocks are written and rewritten over and over again as files get recorded, then watched, then deleted. The frequency of rewrite and reuse of the blocks is much higher .
SSD comparisons and tests seldom take this difference into account, and correctly show life expectancies as comparable or nearly comparable to hard disks, but only for situationan where reuse is not extremely high.
I have yet to see good and independent measurements of SSD longevity when used in video recording and playback with constant deletion and replacement. I am guessing it would show a severe penalty for the SSD.
It was my experience that the Samsung Evo, with the highest number of reuse cycles in the industry for SSD’s, began to slow down somewhat within less than a year of use on my Tablo. I am not sure this is typical. And obviously depends on the frequency of new recordings, deletions, and reuse of space.
One final point is that computer systems employ TRIM optimization to dynamically maximize reuse and longevity performance. Such capabilities do not exist in devices like the Tablo, which potentially prevent the drive from getting this additional significant boost in longevity.
As in all such matters, your mileage may vary…
Larry
