Amazon fire stick 4k
hi, does anybody can tell me why when i select setting to go in my tablo setting on my fire stick 4k, the setting appear in the screen but i can not get in?
Aren’t there two tablo apps for the Fire TV stick. The regular tablo app and the preview tablo app.
Have you installed and tried both of them?
hi zippy, thanks for answer, i just tried it, and it did not work
The tablo app (non-preview app) won’t enter the setting menu until the sync is done. At the very top under the tablo name is where it indicates it is syncing. The sync for this app can be very slow. Especially if the device has not connected in a while.
The preview app doesn’t have a settings menu item. You use the up arrow until the tablo name and both okay and right arrow should enter the settings screen. This app doesn’t have to wait for sync to complete
