Agree with @snowcat , unplug everything and then plug in the modem and let it come back up, then do the router, and then the Tablo. This has happened to me before, and it has fixed my issue.
Thing is live buffering and new test recordings work well. The existing schedule is just being ignored. I though incorrectly this had been established with clarity.
Did you every get this addressed? I was having similar issues with scheduled recordings not happening. I looked in the TV Guide (under Live TV) one day, the shows were showing as scheduled. The next day, I would look at the same spot in the guide data, and the scheduled spots would switch to “To Be Announced” and then the recording would not occur. I wrote support and they said they would check with the TV guide data provider, and gave me a workaround to manually schedule the recordings. Never heard back from support again on the ticket I opened.
It should be said that, while I appreciate the workaround, if I have to manually schedule everything, what is the benefit of paying Tablo for the TV guide data?
This is what worked for me. After 2.2.26 is verified installed go to Settings > Update Now (in the Guide section). Says it was updated? Doesn’t matter. Click Update Now and keep doing a few more times for good measure. After 15 minutes, go to your “Coming Soon” list and it should populate with your schedule like 2.2.22.
Not supported I believe, but snapper timeline scrubbing compared to most USB 3 spinning media. Scrubbing through playback of 720p is instantaneous on gen 1 hardware. Downgrading to a fast USB 3 solid state solution stick is an upgrade if you don’t store much, and let auto-delete work its magic. You should try it and compare.
