Adding Channel Numbers To Streaming Channels
With regards to the Tablo 4th Generation.
Many streaming channels have long names (and sometimes cryptic), so much so that you can’t read their logo or tell what channel you are choosing unless you have an enormous TV or sitting very close. It’s much easier for my elderly mother to remember a number of a frequently used channel then remembering the name of the channel. Even if the channel numbers had to start from 1000, it would be easier for my mom (and myself) to remember a number and navigate to it with the up down buttons.
Can Tablo make it so that streaming channels have and show channel numbers next to the channel logos and in a font that is 1/4 the height of the screen so that it’s easy to read?
Thanks
