I have had a 2 tuner Tablo for some time now and really enjoy it. I just bought a 4 tuner unit. I am toying with the idea of keeping both of them and using them simultaneously. Is that possible? If so do they each have to have their own hard drive? And do I access them as one or are they each accessed separately? I tried finding articles on this in FAQ, community forums, etc. and was unable to find anything. Can you please help point me in the right direction?
Yes, you need a hard drive for both. And yes they are accessed separately. I have the same setup as you. One thing I requested or mentioned was to allow them to be accessed or used as a single unit, however, I think that will be a LONG time off if ever.
When you startup Roku Tablo app the first screen after startup is which Tablo you want to use. I will post a picture later, I have to go out for a bit.
Thank you very much that’s helpful. I suspected that was the case. Yes, I’m sure that being able to access them simultaneously is (probably appropriately) way down low on their priority list.
What do you need 6 tuners for? Lol There can’t be that many OTA channels
Sell the 2 tuner for a pretty penny.
@theuser86 I can tell you why I have them, my wife has her shows and I have mine And no, 4 would not be enough
@theuser86. Good point! Unlike @Jestep I certainly have no need for six tuners. However I do want to have 4 tuners available, and at the same time I don’t want to have to get rid of all the programs I’ve saved on the hard drive for my 2 tuner unit. Thus I guess I’m stuck with both units for a while until I can empty out the important programs on my two tuner hard drive. I plan to stop all recording on the 2 tuner a unit in the meantime. As I understand it, you can’t transfer the recorded programs on a hard drive from one unit to another. Is that correct?
Separate his and hers DVRs, you are a genius I’m telling my wife we need another Tablo!
Got them set up now. Working great and Wow, I am amazed at how much faster the 4 tuner unit is compared to the 2- tuner. Very glad I upgraded. I bought my 2 tuner unit very early on (I pre-ordered before they were released). I wonder if the earlier units were just slow and even the newer 2 tuner units are this fast? Or are the 4 tuner units just faster. Just curious.
I plan to watch all I need to on the 2 tuner unit’s hard drive then sell it on ebay.
Klem, in what way is your 4-tuner faster than the 2-tuner that you have? I just got the 2-tuner unit last week and it seems pretty fast to me but I have nothing to compare it to
@fella1 with my 2 tuner after clicking on “live TV” for example, it would take about 15-20 seconds to load, now with the 4 tuner unit it takes about 1-2 seconds. changing channels in live TV takes about 5-10 seconds on the 2 tuner and 2-3 seconds on the 4 tuner, etc. A big difference. But again, I bought my 2 tuner as a preorder, it was likely part of the 1st batch they sold and maybe the newer 2 tuner units are faster. I’m not sure.
