My Tablo is connected to the main TV with ethernet. On my second TV I can’t access the Table to watch recordings. I guess it’s because the main unit is not Wi-Fi. Is that correct and what can I do to access Tablo recording on multiple TV’s?
thanks
tim
What kind of TVs are these? Or what kind of streamer box (Roku, AppleTV, etc) are you using with each TV?
If all TVs/Streamer boxes are on your local LAN (Ethernet or Wifi), then they should all be able to access the Tablo.
My main Tv is also ethernet and my other 3 tv are wireless. I am using various types of roku but all work. You may also want to check that your 2nd Tv can receive the signal. I do use a wireless repeater to insure a consistant signal
Just to clarify - when this person says “signal” they are referring to your WiFi wireless network signal, not OTA signal.
OTA signal is only important for the connection to the Tablo.
