Access to raw recordings
Is there a way to access the files off the hard drive over the network?  I’d like to copy them to my hard drive to play in vlc if I want.
One way is with SurLaTablo
It requires Python 2.7 and ffmpeg.
The ffmpeg part is to convert them from mpeg4-ts to mp4.  Rigth now the program does check the location of the FFMPEG variable which can be set in program or in surlatablo.conf in your home directory.
SurLaTablo works on Windows, Mac OSX and Linux.
There’s no ‘official’ way (although this this on the to-do list).
Lots of folks are using @cjcox’s method though.
