Yeah some really nice member here helped out with the Tablo Android app apk.
I got the file on my PC, copied it to my phone and installed an app on my phone meant for sideloading things to FireTV - it’s specific for that and looks for FireTV devices on your network.
Pushed and installed the app using that app on my phone.
(but found that you have to allow installation of apps from other locations and go into developer mode on FireTV stick first!)
I then wasn’t able to get the BT mouse to pair, so found a “settings.apk” file and sideloaded that from my phone, too, after downloading it to my PC.
Once the mouse was paired and Tablo apk installed on the FireTV stick, and found that FireTV was registered to me already but they left it at Pacific time and fixed that, I accessed the Tablo app. Good results.
My router is a Netgear 2200d. It’s fairly beefy, IMO, for a home router. It’s an N300 router and my notebook routinely connects at that and moves between 150 and 300.
The downside is that it’s a 2.4 Ghz only router - no 5Ghz option, but that’s not been an issue for us so far. We don’t have much in the line of other wireless devices or at least none that cause us issues.
Tablo is wired to the ports on the router (it has 4 10/100 Ethernet ports and Tablo is wired directly to one of those, another goes to my Cisco switch which runs the main computer in my downstairs office)
I let the stick connect to my Netgear router - it did so quickly after I fumbled the remote to get my complex password entered in the stick! The router is 3 feet from the FireTV stick with only the TV’s back between them. So, it’s FireTV stick wireless to router, router wired to Tablo.
That has to be better than:
Tablo wire to router,
router WiFi to notebook PC or phone; phone or notebook PC WiFi to Chromecast.
That’s traffic to and from a PC or phone WiFi, double traffic where the stick is only WiFi from router to stick. 1-way traffic so to speak instead of double-WiFi as I refer to it, technically correct or not.
The interface is clumsy as you can’t easily exit a show you are watching then decide to pause, but the performance was better than expected.
I could do a direct comparison between using the FTV stick and Chromecast, for example. A show that was nearly unwatchable via PC and Chrome was perfectly steady, rock solid even with the occasional pixels it had due to prior antenna issues.
Tablo recorded show to FireTV stick was about as good as watching live through the TV itself and was better than watching it from a DVD recording.
I have very high hopes for this combination as long as they product a good application specifically for the FireTV devices. If that happens, this should be a great combination with great performance, especially if you check out the FireTV specs.
