A couple issues
I have been using the Tablo app and the Tablo beta app. The beta loads quicker, but sometimes it doesn’t ‘hold’ the recording images as long. That is to say, when you scroll down in either app, the Tablo app loads and ‘sticks’ show images better (noticeably better). If they are accessing the same info, why is this?
Also, when I start a recording, it begins 15 seconds into the show on either app, why is this? Really annoying. Sometimes I can rewind the 15 seconds, other times when I do that, it kicks me out of the app. The kick out seems more prevalent on the regular app.
Just to add… my internet is 12Mbps (runs Netflix and other streamers just fine).
One other thing. I have chosen to have my Tablos start in the Recordings tab. Whenever there is any sort of update, it resets my preference to Remember Last. Again, annoying.
All these issues have been going on for some time, I’m just finally posting about them.
This is thru a 4k FireTV on a Google Mesh network and I have my settings at HD720-3 Mbps which is ‘recommended’.
