The new HDHomeRun Extend that was released last year does do 5.1 audio for recordings (obviously, as long as the show is in 5.1). I have my Extends’ “Default Transcode Profile” set to “heavy” and the Extend output file is a TS container with a MPEG-4 video stream and an AC-3 5.1 audio stream (take a look at the MediaInfo output below for more detail). My PVR software is NextPVR on Windows 10 (going all the way back to Windows 7) on an old desktop PC. One hour of recorded TS video on the “heavy” profile is usually a little over 4Gb. Even with the old PC, I sometimes record 3 shows at once. These individual files can be easily backed up, moved, copied, taken over to someone else’s house to watch, etc.
I have automatic remuxing (not transcoding, the streams are not touched) to a mp4 container setup with MCEBuddy. I have MCEBuddy remove the commercials and remux the file to a different container (it does the remuxing at night and we watch all our shows at a later date, sometimes weeks later). My final folder/file output is friendly to both Kodi and Plex. I run Plex server as well to transode whenever necessary to the Plex iPad and Android app.
My clients are either Fire TVs (bedrooms) or a small Zotac Zbox with Kodi 17.1 in the living room (I could use the FireTV in the living room as well). The Zbox in the living room passes through my Onkyo receiver and it has worked fairly flawlessly over the years (the Onkyo receiver displays Dolby Digital when passing through the audio). By far the hardest part for me was setting up the outdoor antenna and getting it to work properly where I live at.
However, I wouldn’t recommend that setup to a person that’s only about convenience, and only convenience. Meaning, if you don’t like tech and learning, then it’s probably not for you. It’s not overly hard to setup at first (just a lot of reading, watching videos, and configuring), and once it’s setup, it usually just works, and I’ve rarely had issues over the years. No more than with Comcast or DirecTV.
But, and this is a big one, you’re the tech support for yourself. If something isn’t working, you gotta fix it. I personally don’t see this as a minus, but a plus. I don’t have to wait on Comcast or DirecTV to get something working. I can start fixing it immediately. Yeah, I’ve had stuff happen over the years. Things break, both hardware & software, but it gets fixed as fast as I want it to get fixed. Amazon next day shipping solves many issues.
I’ve got my Mom setup similar (but more basic) with one old HDHomeRun Connect, an old laptop, and her FireTV. She uses MrMC (a Kodi fork without the addons) on the FireTV to watch her recorded shows. However, I manage the whole setup for her. I considered a Tablo for her, which she could probably manage herself, but I already had an old Connect and laptop, so the initial cost was minimal for me, it just took a little time to setup. Again, the hardest part of the setup was the outdoor OTA antenna and all the coax cable, getting the antenna pointed properly, etc. I would had to do the same with Tablo or any other of the home PVR solutions.
My Mom’s current setup is much better the her old one with Comcast basic cable TV which wasn’t even HD, just SD (it looked horrible). Plus now, Comcast requires a cable box for even basic cable TV, and they’ll soon start charging a monthly fee for that box as well, if they haven’t already. A Tablo would probably have worked as well or better for my Mom, but with the minimal costs and already knowing the whole HDHomeRun setup, it was cheaper/easier for me in this case.
I probably would have purchased a Tablo by now, just to test and play with, if not for the lack of 5.1 audio. They’ve had awhile to add it/release a new model, but for some reason they don’t consider it important, or something else. They’ve got their metrics, but something just seems a little odd about not having it. Fortunately nowadays, there’s a lot more choices than there use to be for consumers, so if one tech item doesn’t match your criteria, just try another one. Just don’t be too wary of learning something new. Also, if you don’t like it, just return it, it’s that easy.
Here is an example of the HDHomeRun Extend “Heavy” Profile TS video file output from MediaInfo before I remux it:
FILE
Complete name : The Blacklist Redemption_20170330_22002300.ts
Format : MPEG-TS
File size : 4.34 GiB
Duration : 1 h 3 min
Overall bit rate mode : Variable
Overall bit rate : 9706 kb/s
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 27
Bit rate mode : Variable
Bit rate : 8838 kb/s
Maximum bit rate : 12.0 Mb/s
Width : 1920 pixels
Height : 1080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.142
Stream size : 3.95 GiB (91%)
Color range : Limited
AUDIO
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Bit rate mode : Constant
Bit rate : 384 kb/s
Maximum bit rate : 395 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 176 MiB (4%)
Language : English
Service kind : Complete Main
