I was able to connect my new Fire Stick tonight and I can report that I’m no longer seeing the drop issue with the same recording that drops video/audio while using the Roku. I moved the Roku Ultra into the bedroom on an older Samsung TV and the issue moved with the Roku. Except now it’s even worse.
Do y’all think this is a signal problem when it occurs on the TabloTV/Roku combo but not on the TabloTV/FireTV combo? I think it’s hardware-specific.
@TabloTV I agree that it is hardware specific. I have long suspected an interface problem between Tablo and Roku. Pixelation is caused by a loss of synchronization. The loss of sync is being presented to the Roku and the Fire Stick from Tablo. The Fire Stick can handle it but the Roku can’t.
Winner - Fire Stick
Loser - Roku
Off the hook - Tablo
@Tablotv I assumed in my previous post that the Firestick had incorporated one of the methods used to mitigate the pixelation problem. Not all Firesticks are equal.
The problem starts with the FCC allowing two transmitters on adjacent frequencies too close on the same antenna tower.
There are methods that Roku, Firestick and other similar platforms can use to lessen the problem but not totally eliminate it. Tablo might not be able to do anything to help unless they can reduce the bandwith of the receiver chip’s intermediate frequecy. There might also be a software solution to lessen the impact of short term loss of synchronization digital data. They might have to get in contact with the manufacturer of their receiver chip for assistance.
For the parts of the semiconductor and system industry that I was involved in, I had apps engineers to help customers design our products into their systems. I had multiple engineers who participated in the standards commitees that defined the industry standards for everyone to follow.
@TabloTV One more point. You might be doing overkill with your antenna. A big 60 mile super sensative antenna isn’t required when very close to the transmitter.
There are some very good reasons for not having a super strong signal going to the receiver. With adjacent channels, its possible to reduce the received level of the adjacent chan to the point where it is below the detection threshold. For example, the received level of chns 11 and 21 are equal. Tuning in chan 11 causes 11 to peak and attenuate 21. Ideally tuning 11 will reduce the level of 21 to the point where it is below the threshold where it can be seen by the detector. Having the very best super-duper antenna feeding the tablo can provide such a large signal to the Tablo that the adjacent chan can’t be suppressed enough to keep it from being detected. The solution is to reduce the received signal level presented to Tablo. A Tablo that is 8 or 16 miles from the transmitter will probably work great with rabbit ears.
I couldn’t post the results yesterday because of the posting limit. I would like to know the results, if any, of others changing to a less sensative antenna or removing amplifiers.
My first channel scan dropped chans 68.x. i expected that since that’s been real flaky for a long time. I decided to check further to determine why this 1 megawatt chan shoild have a problem. The experience with chans 11.x and 21.x being on adjacent frequencies prompted me to investigate that possibility. You’ll never guess what I found. It turns out that chan 68.x is transmitting on a frequency adjacent to chan 5.x. Chans 5.x and chans 68.x transmit on actual chans 24 and 25 respectively. Chans 5.x seem to swamp chans 68.x.
I used Google maps again and found a groundlevel picture that showed 7 transmitter towers within a 1 square mile area. 5.x and 68.x are in that group.
The FCC really screwed up by allowing so many chans on adjacent frequencies in the same area.
@TabloTV Well folks, a few days have passed and chans 11.x are still rock solid.
Chans 68.x are still swamped by chans 5.x. this leads me to believe that the IF bandwidth of the receiver is too wide for handling high powered adjacent chans.
Had a real change in atmospheric conditions today with the heavy snow. I don’t know how much 50 miles of falling snow attenuates the signal. It’s enough to allow 68.x to come in partially.
@TabloTV Here is the latest. I last reported that chans 68.x were being swamped by chans 5.x. I turned my antenna about 30 degrees off axis. Not pointing directly at the antenna farm put it on a side lobe and reduced the signal level from all of the high powered transmitters. The result now is that chans 68.x appear to come in solid. Chans 13.x and 33.x are weaker but don’t pixelate.
You need a filter, not an amplifier or fancy antenna. I got the “Philips LTE Filter for TV Antenna” on Amazon ($9.99). It filters out radio interference from cell towers and other devices. Game-changer for me after banging my head against the wall for years due to constant pixelation (also on channel 11, but in Atlanta). It looks like there are plenty of other brands out there at varying prices. I just know that this is what works for me when nothing else did.
Filters didn’t and won’t help me and others in this area. The problem is that the FCC screwed up by assigning transmitters within a 1 mile radius to transmit on adjacent frequencies. The frequencies are so close that enough of it feeds thru the IF amplifier in the Tablo receiver and gets detected. Thus the pixelation.
This problem can be fixed (potentially) with this device:
Among many other features, it has very high slope digital RF filters, along with the ability to digitally reassign RF channels on the output side.
So for example, if two transmitters are on RF channels 23 and 24 respectively, and the Tablo tuners are having difficulty decoding both cleanly, the Avant x can be programmed to reassign RF channel 24 to say RF channel 28 for in-home distribution. In this example, the TVs and Tablo tuners on this distribution (coax) would see the ATSC 1.0 content on RF channels 23 and 28, instead of the original OTA transmission channels 23 and 24.
I have this device, have experimented with this functionality. It works perfectly. However, I don’t need it in my application.
That sounds like a dream come true. Adjacent channels have always been a problem with DTV. I tried to find an old document from my previous life when I was involved in developing standards. Here’s one that explains some issues.
