Does anyone have any instructions on how to perform a reset on a 4 tuner tablo?
It seems the only references I can find are for a tablo DUO.
Factory reset for a 4 tuner tablo. Can’t find instructions anywhere.
The reset is the same on the dual and the quad unit.
Thanks, I see that now. It’s just unsettling in that near the very top of the link, it states those instructions only apply to the DUO.
I eventually found another link that didn’t have the disclaimer but turns out the instructions are the same.
This sentence is supposed to have a hyperlink in it to the link below “NOTE: If you are trying to factory reset your Tablo DUAL, use this article.”
The link below is for the Tablo DUAL, which is different than the link you provided.
@TabloTV could the support knowledge base article pleased be fixed?
https://support.tablotv.com/hc/en-us/articles/115003088086-How-to-Factory-Reset-your-Tablo-DUAL
On it!
Sorry for the confusion @nathanktc
Doing a full overhaul/update of the knowledge base is on the to-do list, but we’ll patch this up for now.
