Just to chime in. Not that I have any answers to this issue. Seems to me if 30 is the output and 30 is the max on Roku then should not be an issue there, but perhaps an issue with the router/network. Just my thoughts.
Naper,
Agreed. I guess I need to now pull out my Cisco router and test the Tablo with that…But if I get the same results with the Cisco then it is the Tablo!
-MM13
Correct me if I am wrong, but isn’t 720p video sent out at 60 fps? So if your FIOS is capturing and playing back 60 FPS while the Tablo is at 30 FPS, that would explain why the Tablo would look different.
The H.264 codec that Nuvyyo uses captures at 30 FPS no matter if it is 720p or 1080p, but 720p video is going to be natively broadcast at 60 fps (from what I can tell).
OK, thats a revelation. I assumed that broadcast was only 30 FPS. So my next question is why aren’t you recording at the 60 FPS. I am assuming most DVRs record at 60 FPS?
-MM13
I think it comes down to the fact the Tablo is a streaming device. Almost every internet stream is going to be 30 fps (Youtube is just now allowing 48 fps and 60 fps videos). By encoding a consistent 30 fps using the H.264 codec, the streams can be played back on practically any device.
I don’t buy it for a second… 720p broadcast at 60fps, nagh!
So far the sports i hav watched are Fox ans ABC. Watching Eagles game now and it the same noticeable frame rate.
@MattMan13 I was about the ask the same thing as @Thumbs
720p encoding is pretty good by Tablo, because basically… Tablo can’t make it worse… The channels are either already 720p content or are being successfully “downgraded” to 720p from 1080i.
Now the question is… Is Tablo’s transcoding from 1080 interlaced to 1080 progressive any good? Basically an upscaling process.
I’ll personally be surprised… As it is such a hard thing to do well… But I’m just now paying attention, due to the need for football at 1080p to be spot on. 720p for football just isn’t cutting it.
@mattman13 view your Tablo settings page to see which channels are 1080i vs 720p. In my area, football games will be on multiple channels, some of which are 1080i and others are 720p. Hopefully that’s true for you too.
I have the 4 tuner model and too notice something going on with the video. I have a Roku 3 connected to a 50" plasma and a Roku 3 connected to a 32" LCD and notice it on both. There is some sort of strange slow down of video when playing tablo live tv or recorded content. It is not to the point where it is so noticeable that it is unwatchable, but still there enough to be an annoyance. I can watch the same shows I recorded on Tablo on Hulu plus and not notice this slow down in video as I see on the tablo. I do not think it is a frame rate issue as these two videos show great examples of 24 fps and 30 fps. The 24 fps examples show how bad the video can be and Tablo does not exhibit this behavior but definitely does not show the video as fast as the 30 fps examples either.
http://youtu.be/bJ-4HvoJ7JA
http://youtu.be/jMhXiklZi1w
@guck11 Both examples display the effect at 24fps that i am seeing, but no where near that bad.
I am still struggling to understand how the Tablo effect can be considered normal. It is clearly visible with onscreen action. At 30Fps it should be able to keep with broadcast TV. It seems like it is dropping frames during recording because it cant keep up. The playback is consistently showing the effect.
Anyone know of a way to estimate fps being displayed on the destination device?
Here is good discussion of frame rate. Still think this not about 30fps, but rather the way that Tablo is recording that data.
http://m.neogaf.com/showthread.php?p=97957757
FYI, just had time to watch part of a football game and found a surprising cause of my issues… my Roku 3 was still set to 720p output. I’ll need more time watching content to be sure but right now, this down-the-chain setting has dramatically improved fast motion artifacts.
Ok, watched a 1080i football broadcast, recorded in 1080p by tablo, displayed in 1080p by a Roku 3… and it was just horrible! Worst thing I’ve seen from Tablo… but probably a Roku issue… but who knows.
My Roku3 has always been set to 1080p. I have not necessarily noticed any subpar images, though from what I’ve read 1080i’s bandwidth requirements do tend to introduce digital noise. My 720p always looked as good from a detail perspective as 1080i and my DVR recording.
I checked my 1080i recording of the KC game and the 1080i issue seems to be fixed. However, same choppy picture.
I think the Tablo should handle this, but for some reason it is doing something funky with the encoding.
FTR, this issue is with all recordings, though it is most prominent with sports.
So here are my image comparisons of a roku 3 at 1080 vs 720 with tablo content...
example 1, roku display at 720, tablo encoded at 720
example 1, roku display at 1080, tablo encoded at 720
notice the improved ghosting
example 2, roku display at 720, tablo encoded at 720
