Until 2 weeks ago my 4th generation Tablo worked fine and then went offline and this is a relatively new system. I did all the suggestions to fix but nothing worked. All the Tablo does is blink blue. The app won’t connect either. I tried connecting using the ethernet and still only blue blinking. I have Roku and regular tv and my internet connection is excellent. So I don’t know what to do at this point. If there is an update, I am unable to do- offline.I would appreciate any assistance to resolve this issue.
First try opening it with the mobile device you used to set it up. If you can’t open it from that device, you may need to set it up again. If it does work, try uninstalling the app from your Roku and reinstalling it to see if that fixes it. Also try unplugging the power from your Tablo to restart it, and reboot your router.
Sorry you’re running into that @suzzie,
Would you contact Tablo Support? They should be able to help.
