Can a hdmi and networked tablo work together on same network? How will it show up on remote tvs?
Since multiple networked Tablos work on the same network and since there isn’t a difference in the Tablo app between network and HDMI models, having both should work fine.
When you first connect to a Tablo, you will be presented with a list of Tablos on your network to select from. After that, it should remember which one you initially selected and automatically connect to it. If you want to switch, go into setting and select “Disconnect”. Then it will go back to the list.
